Got the new parts put in finally!
Been riding it every day to work
Seems to be running really good, this morning was the first ive even had to use the choke to start it, and I think that was just cuz it was like 50 degrees. The other day the fork seals blew. Ive been reading up on doing the work myself. Trying to get ahold of some yamaha progressive springs also, so I can change those while Im in there. My forks dont have drain screws on them, it looks pretty simple to just drill and tap out the spot where they should be once its all apart. Is there anything special or something I need to look out for when drilling and taping them? I got Bel Ray 10 wt fork oil. Im a light guy(150lbs) and ride on some rough country roads mostly, if I go with a thicker wt will I benefit much from it or should I just stick with the 10? It will be about a week before all the parts come in, will I be ok riding with leaking fork seals/ possibly no oil left? or is it time to park it before I damage something?
Here is my list of parts I plan on getting in the next week or so:
yamaha fork seals and dust boots
Ignition, fuel cap, and seat latch(a flathead screwdriver is my key for everything for now
ebc HH+ brakes front and rear
double bubble windshield(any suggestions on a brand?)
HJC CL-Max II helmet should be in by the end of the week
