Anyone have the progressive suspension shock on their bike?
Hi Im looking for feedback for anyone that has the progressive suspension shock on their bike. Please reply back thanks
Re: Anyone have the progressive suspension shock on their bi
I did. And didn't really care for it. It works a little better than the factory shock, but that was about it. In terms of suspension options goes, if you can't get a Fox, Ohlins, or Penske then the Progressive is a better option than stock. But I had to order mine which took 4 weeks and it was over $400+ new. For that kind of money, you can always find a higher performance shock for that kind of money.
So whats better the progressive suspention shock or a R6 shock?
Why not do the r6 shock?
'92 FZR600
Lots of Powder
Lots of Powder
So whats better the progressive suspention shock or a R6 shock?delvryboy wrote:Why not do the r6 shock?
Well, shock and dog bones would run you $100-150. A new spring for weight from race tech is $110. So for $250ish, you could have a pretty sweet fully adjustable setup.
Sent from my NookColor using Tapatalk
'92 FZR600
Lots of Powder
Lots of Powder
thatkid has a sexy, sexy fox shock for sale....
Upgrades:
Hi so when ya had the progressive suspension shock what kind of adjustable settings did ya have?cad600 wrote:I did. And didn't really care for it. It works a little better than the factory shock, but that was about it. In terms of suspension options goes, if you can't get a Fox, Ohlins, or Penske then the Progressive is a better option than stock. But I had to order mine which took 4 weeks and it was over $400+ new. For that kind of money, you can always find a higher performance shock for that kind of money.
Rebound damping is all. If you are going after one of these, do not buy one new. Seriously, you can buy a much better shock for the money.
