tail light
Posted: Tue Aug 16, 2011 9:43 pm
by floridafzr600
ok the dbag that had the bike before me has 2 2in round led brake lights that are blacked out if i get a clear stock brake light bulb and lens set up can i cut the center tail and have it bolt right on and if i can where can i get a clear lens setup
Re: tail light
Posted: Tue Aug 16, 2011 9:46 pm
by zero9243
I'm having a hard time visualizing what you mean, but the stock lens doesn't really bolt onto these bikes, there are clips that hold the lens in, and housing that holds the bulbs. Is the housing still on the bike?
Re: tail light
Posted: Tue Aug 16, 2011 9:55 pm
by floridafzr600
i cant take pics at the min put if you take the back seat off of my bike there is a square there where you can lose a soda can but the center tail the guy has on there is like the stock one but instead of the cut out for the rectangle lenz its solid with 2 2inch holes cut into it and thats where the tail lights are?
do you have a face book i have pics on there
Re: tail light
Posted: Tue Aug 16, 2011 10:00 pm
by floridafzr600
its a totally different center piece set up imagine the center tail without the stock tail light and two circle tail lights instead like the stock wouldnt work unless i cut the tail to shape it
Re: tail light
Posted: Thu Aug 18, 2011 11:39 am
by floridafzr600
ok in the back of the tail there is a rectangle slot and some holes to but bolts or clips into
