Packing Bearings???
Posted: Mon Aug 15, 2011 8:02 pm
Well i finally think i solved my problems with my steering issue. I took my front end apart and then took a look at my steering stem. It felt realy rough and didn't want to move smoothly. Took the neck apart and found that there was no grease and if there was it was all gunked up and dried up. The bearings didn't move at all unless you put alot of effort and the other bearing was somewhat greased and rolled around but wasnt to smooth like it should be. Gonna take it into work and clean the bearings realy good in the parts washer and repack them with good grease.
Question i have is how tight should i tighten the top nut. I know i have to tighten it and back off it a little but how tight should it be???
Any recomendations or precautions in doing this job???? Anything to look for while this is apart????
