anyone located in southern NH
jfrankel06
Post by jfrankel06 »
anyone located in southern NH by nashua or manchester that would be willing to help me with some float height work? in some serious need of some help
pefrey
Level 5.5
Level 5.5
Re: anyone located in southern NH
Post by pefrey »
How do you know your float heights need to be messed with? There's a lot of knowledge on here so if you ask a lot of questions and take your time, you can probably do it without hands on help.
jfrankel06
i called yamaha and they said to adjust my foat hights they think its getting to much fuel and flooding out
jsph.mitch
100+ Posts
100+ Posts
Post by jsph.mitch »
What's it doing. Details. Adjusting the floats is not to hard. It just takes time. I just did mine. Search around. Someone posted a how to, and its spot on.
Sent from my ADR6300 using Tapatalk
91 FZR600
Trimmed Tail
YZF VR Upgrade
LED Taillights
Many more mods to come.....
jfrankel06
after taking off the carbs and looking everything over..do the jets need to be all the way in or backed out a certain amount?..put the carbs back together then hooked up the fuel pump and turn the petcock on.. bike started up fine ran for 6 or so min and then i shut her off..went to put her back together so i could take her for a quick ride..once i put her back together..she wouldnt turn over again..i dont kno much about bikes but im thinking she is flooding the carbs...hmm
jfrankel06
jsph.mitch
100+ Posts
100+ Posts
Turn over? Do you mean won't start?
91 FZR600
Trimmed Tail
YZF VR Upgrade
LED Taillights
jfrankel06
yes wont start
Target30
Level 7.5
Level 7.5
Post by Target30 »
where are you located? you probably need a good cleaning and sync. more details!
does it turn over, and just chug?
does the fuel pump click(prime) when you turn the bike on?
when you have it running, what rpm does it idle at after it is warm?
do you leave the choke on while you are riding?
lastly, does your bike have this color scheme? an you ride it around Milford, NH?
:whistle
I did that.
jfrankel06
im located in litchfield nh...and no my bike does not have that color scheme lol..and i havent been able to ride it yet to see how it rides..i bought it from a kid that told me it only needed a new fuel pump...it starts now after the petcock has been off for a while..then runs rich..and then dies when i go to put it in gear..sometime just when i rev it..then it wont start again..my assumption..its flooding now..no clue how to fix this problem...
jfrankel06
also if i hold the throttle all the way open and try to start her..she starts for a quick couple seconds and then dies...when i had her running last she was idling at 3 grand...hmm.
jsph.mitch
100+ Posts
100+ Posts
I think your right about the flooding. I had one fuel needle go bad, and it caused big problems. When you had it running, did you smell un-burnt fuel in the exhaust? I would pull the carbs apart and check the floats, the float heights, the valve needles, and the jets. Get everything a good cleaning. Then put it all back together. While the carb is sitting in front of you, bench sync it. Make certain if the problem is the fuel valves, you replace them. If you keep attempting to start the motor and the fuel is just pouring into the combustion chamber, you can hydro lock the motor. That's bad.
91 FZR600
Trimmed Tail
YZF VR Upgrade
LED Taillights
jfrankel06
alright will tackle that on monday..thanks man
Target30
Level 7.5
Level 7.5
Post by Target30 »
you are defiantly in for some carb work. it really isnt as hard as you would think. there are some good guides in the wiki. if you get stuck, and feel like driving, you can bring them over and i can help. i'm near milford.
I did that.
jfrankel06
thanks target im gonna try to tackle them now..if it doesnt work out so good i will deffinatly PM you and see if you have some free time..and if i do get this thing running i would love to take a ride out anyway and see your bike
