I have searched, but maybe I don't know what to search for. My issue is my RPM gauge is not right. It dances all over the range. While going 55-65 mph, its reading between 2k and 10k. I am not sure how to fix it. Any ideas?
Sent from my ADR6300 using Tapatalk
RPM gauge.
- jsph.mitch
RPM gauge.
91 FZR600
Trimmed Tail
YZF VR Upgrade
LED Taillights
Many more mods to come.....
Trimmed Tail
YZF VR Upgrade
LED Taillights
Re: RPM gauge.
If your bike is running fine then I would suspect the gauge. You can confirm by buying a cheap tach from autozone, wiring it in and seeing if it misbehaves, then return it when you're done. Stock tach should read off the neg terminal on one of the coils. I would Chase down the wiring and see if something is loose and breaking connection due to vibration or wind. If that's not it I would guess the spring in your gauge is shot. Try searching tach problems instead of rpm gauge.
96 fzr600. R1 body kit.
94 xj600 seca 2: complete upgrade restoration.
73 Honda cb750 four: bored out 178 over (850 cc) street cam, smoothbore carbs, velocity stacks, corbin king-queen seat, 4-1 header with modified megaphone exhaust, dyna-s ignition, too many other mods to mention and still under construction.
72 Suzuki ts90 cci. First bike ever, bone stock and still starts with 2 kicks.
Re: RPM gauge.
For the 600s, only the '89 'W' model drove the tach off the 2-3 coil negative. The '90+ bikes had a dedicated signal wire coming off the TCI.
That said, I completely agree with CSC's troubleshooting thoughts of loose connections / frayed or broken wire. Check the screw terminals on the back of the gauge cluster first; if any of the 3 wires going to the tach have intermittent contact, then it will bounce all over the place.
- jsph.mitch
Re: RPM gauge.
I had the guage off a while back. While it was off I wire brushed the connectors, and put them back with some die electric grease. I guess I just need to chase wires. I replaced the VR thinking that might be the problem. No luck.
91 FZR600
Trimmed Tail
YZF VR Upgrade
LED Taillights
Trimmed Tail
YZF VR Upgrade
LED Taillights
Re: RPM gauge.
Replacing the VRR does not in and of itself solve anything. It prevents further damage, but doesn't un-fry any components that took a high-voltage hit. If you've had a bad VRR, you need to go in and repair or replace anything that got killed.
- jsph.mitch
Re: RPM gauge.
I think I am just going to live with it until winter when I pull the bike apart.
91 FZR600
Trimmed Tail
YZF VR Upgrade
LED Taillights
Trimmed Tail
YZF VR Upgrade
LED Taillights
