Does my FZR needs to be rejetted for a UNI foam filter?
Posted: Wed Aug 03, 2011 8:28 am
by Crying Freeman
I've just purchased a UNI foam filter for my FZR 600. It states that the bike may need to be rejetted. Does anybody here have an UNI or K&N filter on their FZR and needed to rejet their carburetors?
Re: Does my FZR needs to be rejetted for a UNI foam filter?
Posted: Wed Aug 03, 2011 9:00 am
by Crying Freeman
I found my answer and my carbs don't need to be rejetted. The following details are from powersports.net and from motorcyce-superstore.com:
http://www.motorcycle-superstore.com/1/ ... Parts.aspx
http://www.powersportparts.net/UNI-FILT ... u-3227.htm
UNI OEM REPLACEMENT AIR FILTERS
*Fits exactly like the original equipment air filter
*High flow Uni-filter will improve performance and provide the best filtration and engine protection available
*Uni-filters can be easily cleaned and reused
*“Flow Matched” filters need no rejetting
Posted: Wed Aug 03, 2011 10:02 am
by ragedigital
The basic rule for re-jetting is that "if no more power is going out, then no more power is going in". In a nutshell, unless you modify your exhaust, then chances are, the motor is not pulling in any more air regardless of the filtration change.
That rule doesn't necessarily apply to forced air systems... blowers, superchargers.
Posted: Wed Aug 03, 2011 6:16 pm
by Crying Freeman
Thanks for your response...will keep that in mind...
