carb needle washer order
Posted: Thu Jul 10, 2008 6:29 pm
by tommyj27
ok, got my carbs half apart and realized that i must have been out of it the last time I had them apart because i've got the order of the washers on the needle different on different carbs. Is the order supposed to be:
metal flat -> e-clip -> larger plastic -> metal flat
or
e-clip -> metal flat -> larger plastic -> metal flat
Re: carb needle washer order
Posted: Thu Jul 10, 2008 7:42 pm
by tommyj27
settled on
flat metal -> e-clip -> flat metal -> larger plastic
hopefully that's right, it makes more sense. i don't know what the hell i was thinking before
Posted: Thu Jul 10, 2008 10:19 pm
by ragedigital
In order from top of needle:
Small washer
E-clip
Plastic Washer
Large Washer
This should help:
Posted: Thu Jul 10, 2008 11:28 pm
by tommyj27
my metal washers are the same size, but sounds like i got it right. i'll let you know how it's running with the new tubes, so far so good; the throttle response is better than it was with my needles set on the very leanest setting. no more bogging down off the line.
Posted: Thu Jul 10, 2008 11:29 pm
by tommyj27
oh wait i'm kind of backwards, i'm too tired to think about this shit. :duh:
Posted: Fri Jul 11, 2008 5:01 pm
by megaloxana
I have two sets of carbs and both only have 1 metal washer :headscratch: small metal washer-->clip-->plastic washer
Posted: Fri Jul 11, 2008 7:41 pm
by tommyj27
My bike ran fine yesterday with the order not quite right, so order obviously isn't critically important.
Posted: Fri Jul 11, 2008 7:49 pm
by ragedigital
No, you shouldn't have an issue. But, I'm sure down deep it's going to bother you knowing that at any time the bike could blow up instantly from your one little mistake...
Posted: Fri Jul 11, 2008 9:01 pm
by tommyj27
ragedigital wrote:No, you shouldn't have an issue. But, I'm sure down deep it's going to bother you knowing that at any time the bike could blow up instantly from your one little mistake...
It will, I'll probably end up tearing everything apart again to fix it.
Posted: Fri Jul 11, 2008 10:20 pm
by ragedigital
It should have no effect at all. But, if you're like me, it will burn a hole right through you knowing it's not in the right order.
Yes. I have a problem.
