problem i have with tranny
jos21802001
Alright i have the whole right up on trans and i have my hanyes book........ my problem is i know messed up shift fork or my drum ..........i pull shift rod b out no problem at all.......shift rod a is not moving at all tapped it a little nothing ...... if i use a srewdriver it wil shift into first no problem but if i try to go into 2nd the shift drum is moving out like a 1/8th of an inch so i stop and put it back into net and it is good. How can i get shift rod A out? so i can get drum out and see what i broke?
1989 fzr 600 candy silver base coat, black frame ,voltage up-grade amoung much more
jos21802001
Re: problem i have with tranny
here is a pic to show you the shift fork that is being tight. The other one on the rod is moving free but the one marked well it is not any advice?
jos21802001
think i found my problem that bent shift rod
tranny works good and looks good checked teeth and all inside
also noticed the u was bent a hair out so changed shift shaft rod out also
SHE SHIFTS INTO 2ND now YEAH few more hours and she will be back on road can't wait
