Just heat tuned my carbs and I have a question
So thatkid and I split the cost on a nice carb sync tool and yesterday we finally got around to tuning our carbs. He also had an IR heat gun so we did heat tuning as well. We noticed, though, that when we were tuning my bike, my headers were sitting in the 600-650 degree range, and his were sitting in the 180 degree range. Now, I know that my bike has had some type of engine work done, but I don't know what. It just seems like a huge jump in temperatures to me. We both have aftermarket headers (idk if that would matter). I also know I'm not overheating because my radiator fan doesn't even turn on. What are most of you guys running as far as heat when you tune and should I be worried about my high temperatures?
Upgrades:
Re: Just heat tuned my carbs and I have a question
What RPM was that at?
idle. roughly 1.2 - 1.4
Upgrades:
Is it appropriate to add that my frame will never again be hot thanks to some awesome frame coolers from thatkid!!
Upgrades:
Always appropriate to add something awesome I did.zero9243 wrote:Is it appropriate to add that my frame will never again be hot thanks to some awesome frame coolers from thatkid!!
I'd say it was a joint effort but we all know how you like the spotlightthatkid wrote:Always appropriate to add something awesome I did.zero9243 wrote:Is it appropriate to add that my frame will never again be hot thanks to some awesome frame coolers from thatkid!!
Upgrades:
what are these frame coolers of which you speak?? i am intrigued...
Leftover 07 Silver Ninja ZX6-R
**SOLD**
1990 FZR 600 Satin Black / Metallic Black Frame / Metallic Copper wheels
- Mods -V&H PIPE & HEADERS - 1999 R6 TAIL - 2001 UNDERTAIL - INTEGRATED LED TAIL LIGHTS - 2000 YZF TANK - 1995 YZF FRONT SUSPENSION AND GUAGES - MICHELIN PILOT POWER 120/60 ZR 17 - 1995 YZF REAR SWING ARM AND WHEEL W/HUGGER - METZLER ROADTEC Z6 170/60 ZR 17 - Xentec 8000K HID HEADLIGHTS - WHITE LED LIGHTING KIT
**SOLD**
