got another guess the brand
Posted: Wed May 25, 2011 9:00 am
by jos21802001
of you did so good on my last one. lets see what I can find out on it . This header doesn't look stock to me but i can be wrong. It is on my 1989 yamaha FZR600. Kept in mine this was a bike raced up at Summit Point and I bought it and put it back on the street.It fits under fairing but really close to the right on also had to trim out bottom of fairing where meets mid pipe.
Re: got another guess the brand
Posted: Wed May 25, 2011 9:25 am
by Target30
to be honest it looks like an Vance and Hines SS2R full system header, but it doesnt have the spring hooks on it
Posted: Wed May 25, 2011 9:42 am
by jos21802001
i was thinking the same when i started looking at it the only thing that throws me is it goes stright back then kick of to the left at 45 degrees
Posted: Wed May 25, 2011 10:40 am
by zero9243
Vance and Hines i'd say
Posted: Wed May 25, 2011 11:11 am
by FasterThanUr
Thats a Muzzy I believe.
Posted: Wed May 25, 2011 11:18 am
by jos21802001
why can't they just badge them from the start lol
Posted: Wed May 25, 2011 11:33 am
by FasterThanUr
I think they have a S/N # stamped on them but it probably rusted off.
Posted: Wed May 25, 2011 12:09 pm
by thatkid
That's the lower model vance and hines header. The supersport I believe. The ss2r has removable end pieces that bolt to the head first and then you slide the header pipes over them and use the springs to secure it. The muzzy offsets the stack at the collector where the V&H puts them right over each other.
Posted: Wed May 25, 2011 1:05 pm
by jos21802001
sweet to think i though it was stock at first before i took it off and started sanding it and respraying lol
Posted: Wed May 25, 2011 6:33 pm
by ragedigital
thatkid wrote:That's the lower model vance and hines header. The supersport I believe. The ss2r has removable end pieces that bolt to the head first and then you slide the header pipes over them and use the springs to secure it.
Less expensive model, but certainly better sounding and I would wager higher performance than the SS2R.
