cartridge filter to spin on Mod
jos21802001
what are the steps needed to do the swap. If you could please help i have been serching on line and can not find much on it. Thank you
1989 fzr 600 candy silver base coat, black frame ,voltage up-grade amoung much more
Re: cartridge filter to spin on Mod
Hi, Jos.
You need the adaptor plate 3TJ-13461-00-00, http://www.ronayers.com/ProductDetails/N/687/SKU/555819
Union bolt 90401-20145-00, superceded to 90401-20007-00, http://www.ronayers.com/Search/N/687/Pa ... /Source/YA
O-ring 93210-87723-00, http://www.ronayers.com/ProductDetails/ ... KU/1111200
There was an adaptor on EBay, but they're asking the same price as Ron Ayers.
Unless I've completely screwed myself up, it literally is unbolt the old filter & housing, and bolt on the new.
(20 minutes of googling later) - Ok, once again Don talks out his backside; there is in fact 3mm of milling to be done. I had checked part numbers earlier, and missed the fact that the '89-90 crankcase is 3HE-15100-01-00, while the '91+ crankcase is 3HE-15100-10-00. According to this post by Dru86 over on the Archives http://www.fzrarchives.com/ipb/index.ph ... t&p=382999, you need to mill down either the center boss in the filter area on the crankcase, or make a suitable socket in the adaptor plate.
jos21802001
thank you for the help man i hope this will also help others out there too
thank you
