need some help on my bike
it runs good then when it heats up it wants to die
Re: need some help on my bike
You're running rich. Check your air filter and airbox for fouling; the filter may simply be past its 'best before' date.
Are your starter plungers ("choke") going fully home when you push the lever off? ARE you turning the choke fully off?
i will check all that today but thanks for the help
