adjusted it the other day and was running fine. 2 days later -- no start.
FZR600R Won't Start
FZR600R Won't Start
Could it be this causing me problems?
Re: FZR600R Won't Start
and no start even though adjusted back. turning over, just won't fire
S,scanty wrote:and no start even though adjusted back. turning over, just won't fire
sorry mate that pic is too darn small to see what the heck you are showing us
sorted, some people say it's to adjust tickover, some say it's the air/fuel mix. whatever it is it won't be getting touched again.
may have been a bit hasty. now won't start again and me battery's dying. got the problem narrowed down, just need the juice to start it. few phonecalls gonna have to be made
that's actually the throttle stop screw
If you have cranked this thing a lot(sounds like you have) without it starting...especially once the battery gets low....I can pretty much guarantee you that you've fouled the sprak plugs.
If you want it to start, I suggest that you put some new spark plugs in it.
Autolite 4303s willl fit and are far cheaper than NGK or Denso
reelrazor wrote:If you have cranked this thing a lot(sounds like you have) without it starting...especially once the battery gets low....I can pretty much guarantee you that you've fouled the sprak plugs.
+5 on that, check the carbs are synched and all should be well
now it starts, but not with the choke. any ideas why that could be?
scanty wrote:now it starts, but not with the choke. any ideas why that could be?
Ok now we are getting some where, she starts from absolute cold no "choke" what is the idle RPM like ?
is there aslight hesitation from idle to say 1/8 throttle
Ditto from 1/8 to 1/4 throttle?
The reason I ask is that the "choke" may be stuck open, the "choke" is not conventional on these bikes it is really an enrichening circuit with its own jets.
If they are constantly on I would expect VERY black plugs, poor gas consumption figures and the hesitations I mentioned.
sorted that, just a case of adjusting the screw again. now replacing the sump i cracked by over-tightening the sump plug.
new query, do i need to use Gasket cement on the sump gasket? wouldn't bother normally but i got someone telling me i have to
mines the same, only likes choke on for a few secs, then idles at 1-1.3 RPM
Guys,ronny86 wrote:scanty wrote:now it starts, but not with the choke. any ideas why that could be?
FZR's are cold hearted machines it could be 70 in the shade and it still needs the "choke" to start maybe not for so long as when it is 32 ish
