poor starting,SOLVED
CJD
Post by CJD »
My bike is difficult to start even with the choke on when it does start it stalls when i put it in gear the bike will start and run if i push start but it's very sluggish and won't go over 3000 revs ive put fresh gas in and changed the filter plugs are new
please help
rotortech
Level 1.5
Level 1.5
Re: poor starting
Post by rotortech »
Did it run correctly for you in the past? Or can I assume that you just got this bike from someone else?
Give us a little history (as much as you know) so we can help you out.
Rotortech
Indianapolis, IN
[list]RaceTech Springs
R6 Rear Shock
FactoryPro Jet Kit
CJD
Re: poor starting
Post by CJD »
got it in febuary the seller told me everything with the bike was fine, and it was now the bike is playing up it did run fine before
Re: poor starting
CJD wrote:got it in febuary the seller told me everything with the bike was fine, and it was now the bike is playing up it did run fine before
CJD,
welcome to our site but PLEASE fill in your location in your personal profile , then we have some idea what market model you have they are NOT the same world wide. There just may be some one here who is not that far away and two heads is better than one.
OK as to the bike problem do you know if the PO had the bike standing doing nothing for any length of time , have you had it parked up since February?
On the front page of the WIKI there is a section that links to "New to FZR's" about basic things you may want to know.
The WIKI contains How To's on carbs & carb tools you can make to help you get it right.
The Search engine can help you find threads related to your problem to give you an insight to the things that most of us have been thro.
CJD
Re: poor starting
Post by CJD »
After a little digging/searching, I found teh remedy. My #1 & #3 plug leads where the fault, i trimmed 1/4 inch off them, problem solved.
Re: poor starting
CJD wrote:After a little digging/searching, I found teh remedy. My #1 & #3 plug leads where the fault, i trimmed 1/4 inch off them, problem solved.
ANOTHER SATISFIED CUSTOMER :grinnod:
well done
ng86
Re: poor starting, solved
Post by ng86 »
Plug Leads? Like spark plug?
This sounds like my bike sometimes..
Looking for a solution as well.
1992 Fzr 600 - Airtech Tail, K&N Twin Filters, Aftermarket Chopped Exhaust, Custom Blinkers (Lol)
CRG Bar End Mirror, R6 Front MC and Calipers
Soon To Come (aka wish-list) R6 Front Forks, YZF Rear Swingarm, Factory Pro Shift Kit, Stage 3 Jet Kit, and New Emulsion Tubes
ng86 wrote:Plug Leads? Like spark plug?
The spark plg leads fray where the screw inside cuts the core of the wire and gradually the core disintegrates and you end up with poor spark/ no spark.
He trimmed off the last 0.25 " and it all works again <BG>
