How bad is fork oil suppose to smell?
- kilika2
- 1000+ Posts
Seriously I took the forks apart and wow. Thick but runny at the same time. Nasty gray color and smells aweful. Good thing I'm changing it huh?
Chris.
Chris.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
Re: How bad is fork oil suppose to smell?
Yeah, it is really nasty stuff. Wear gloves, don't put the fluid in your mouth, etc.
Rotortech
Indianapolis, IN
[list]RaceTech Springs
R6 Rear Shock
FactoryPro Jet Kit
Indianapolis, IN
R6 Rear Shock
FactoryPro Jet Kit
its usually like that....smells awful
SOLD
SOLD
- kilika2
- 1000+ Posts
Hmm gloves. Whoops. Yeah, I ran out of gloves when I was doing the brake lines. So I roughed it through the fork oil. And unfortunatly roughed it through the paint stripper on my wheels. Burnt a bit.rotortech wrote:Yeah, it is really nasty stuff. Wear gloves, don't put the fluid in your mouth, etc.
Chris.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
fork oils come in 5,10,15,20 wt I use Bel-Ray usually .It has to be proper fork oil or it will foam etc. and generally go out on you.kilika2 wrote:Hmm gloves. Whoops. Yeah, I ran out of gloves when I was doing the brake lines. So I roughed it through the fork oil. And unfortunatly roughed it through the paint stripper on my wheels. Burnt a bit.rotortech wrote:Yeah, it is really nasty stuff. Wear gloves, don't put the fluid in your mouth, etc.But I was going to go back with yamaha fork oil. But it's too expensive so I'm going to join everyone else and just put 5w20 or whatever in there. Got to do a search.
Chris.
- kilika2
- 1000+ Posts
Hmmm. I thought I read on here recently that regular motor oil could be used. Might have to just check out the fork oil instead. Thanks Geo.
Chris.
Chris.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
You will need two bottles of fork oil. It will be in there for 10 years. Don't take a chance on using the wrong product. I used the Yamaha fork oil in mine. YG makes a good point about the foam.
Rotortech
Indianapolis, IN
R6 Rear Shock
FactoryPro Jet Kit
Indianapolis, IN
R6 Rear Shock
FactoryPro Jet Kit
use ATF before you use motor oil.
IU use bel ray from the local yammy dealer, its not that expensive since it will last a few years(atf is almost as much anyways)
SOLD
SOLD
Chris,kilika2 wrote:Hmmm. I thought I read on here recently that regular motor oil could be used. Might have to just check out the fork oil instead. Thanks Geo.
Chris.
I never saw that or I would have mentioned the fact that the guys who make & sell fork oil spend loads of money on research to make sure people use their stuff & not say afterwards it was crap the forks faded etc. Ask any one who motocross's good fork oil will save yer manhood and make riding rough stuff a lot easier if the forks work consistently thro a race.
I will say this the nice thing I learned from bel-ray was you can mix weights to get what you need. I had aset of flashy forks on my trail wheels (for Jungle riding in the mountains back home) 20 wt was too stiff and 15 wt was to soggy so i asked if it was ok to mix 20 & 15 in equal portions to get 17.5wt and Lo & behold it worked.
PS:-
ATF as far I ever saw back home was only in 10wt never saw any other and for me at 180 lbs was far to thin
Terrible smell...
+27 on the Bel-Ray
+27 on the Bel-Ray
RD,ragedigital wrote:Terrible smell...
+27 on the Bel-Ray
I do believe that the OEM oil was fish oil based originally and when mixed with water YUK with a capital YU
- lennyz600
amlost as bad as gear lube.
ive had good luck with spectro products.
Lenny Ziarnik
'89 FZR 600 23,xxx mi
'77 Triumph Bonnieville 750 30,xxx mi (the old mans bike)
'03 Pontiac Grand Am GT 114,xxx mi
'72 AMC Javelin AMX
Half of being smart is knowing what your dumb about.
'72 AMC Javelin AMX
- kiki231
+1 on belray
I have been using it for years.
When things get expensive, I become a fast learner...
[i]1989 FZR600
2009 R1[/i]
[i]1989 FZR600
2009 R1[/i]
