Please point me in the right direction.
Posted: Wed Feb 23, 2011 7:26 am
by Bagualinc
Hello all. I have a 1997 fzr600 with an electrical issue that's baffling me ( not that baffling me is a major accomplishment). I took her out for a fill up and of course shut off the engine. When I tried to start her back up - nothing. Only parking lights. No headlights, neutral light, turn signal, horn, brake lights, and of course not a hint of starting. It was running perfectly just prior. The battery and fuses ( including the main fuse) are fine. No funny smell. I just don't know where to start (no pun intended). HELP!
Re: Please point me in the right direction.
Posted: Wed Feb 23, 2011 8:02 am
by kilika2
There is another guy on the board haveing a similar problem. However your no headlights difference leads me to believe that the blue wire that s inside you right hand control has become unsoldered. It's quite common and can strike any time. Even if the bike is working perfectly before that.
I would start there.
Chris
Posted: Wed Feb 23, 2011 11:41 am
by racerd14666
check the relay assembly and its wiring cus if i remember correctly the head lights shut off when you push the starter button but my mid fades me since its ben a year since one of my fzrs had its starter button pushed lol
Posted: Wed Feb 23, 2011 12:27 pm
by cad600
You blew a fuse. Check the fuse block and replace the blown one. Then you need to track down the wire that is grounding out and causing the short. Mine did this once and it was the wire for the horn hitting the radiator.
Posted: Wed Feb 23, 2011 6:42 pm
by Bagualinc
Thank you. All of the fuses check out fine. The blue wire is still attached in the rh control. How many differen wires could possibly cause these symptoms? Obviously I'll begin with a more thorough check of the rh wires and fuse box assembly when I get in tomorrow. Are there any that I can safely ignore or at least hold off on as a last resort. I'll eventually check them all if I have to but I'd rather go in a logical order. Should the wires have obvious damage or will I have to do more than a visual check? :tks:
Posted: Thu Feb 24, 2011 12:22 am
A wire broken inside the insulation can be annoyingly inconspicuous. If you have a continuity tester, that might help.
Posted: Wed Mar 02, 2011 12:53 pm
by Bagualinc
Is it possible that the main relay is the problem? Is there a way to test just that part?
Posted: Sat Mar 05, 2011 3:03 pm
by lennyz600
i had a problem with a pitched wire from the killswitch, i cant remember if my headlights were doing anything when that happened, but it did just ramdomly happen to me.
Posted: Sat Mar 05, 2011 3:58 pm
by Bagualinc
I got a new (new to me) wiring harness and just replaced the wires. Now everything works except the most important part. IT WONT START!!!! I've got lights, turn signals and all of the rest. When I switch the starter button to "run" I get nothing. If I push in the (grey) starter button the lights go off and everything except no starting. I don't even get that grumble I usually heard when I first flicked the red switch to run. I'm just confused now!
Posted: Sun Mar 06, 2011 5:42 am
by jax
check your starter relay. when you push the button you should have +12 come in to activate the relay. If you dont then start wire chasing from that point back to the controls.
and check the kickstand switch and the switch at the clutch.
Posted: Sun Mar 06, 2011 7:08 am
by Bagualinc
Thanks. I'll start there this afternoon.
Posted: Sun Mar 06, 2011 9:12 am
by jax
I would bypass both the clutch and kickstand switches to troubleshoot. Once you figure out what the problem is put them back.
Posted: Sun Mar 06, 2011 9:51 am
by Bagualinc
She's Baaackkk!!! :headbang:
Thank you all so much! After replacing the wiring harness and getting everything but the ignition working I tried to start her via the starter solenoid. It would start so I felt a little relief knowing that I was still just dealing with an electrical issue (not that that's a goo thing). I went through the wiring again and noticed that one of the red/white wires coming from the RH wasn't making contact at the connector. Now all is well! Doing it yourself (with a lot of help from all of you!) feels pretty good. God knows what I would have been charged at a dealer, not to mention getting it there. Plus I've now gone over parts of the bike that I didn't know existed. Thanks again! :tks:
Posted: Sun Mar 06, 2011 5:15 pm
Nice. Now go take some really good pics of the bike and post them.... :cheers:
Posted: Sun Mar 06, 2011 6:06 pm
by jax
Sweet. Glad you got it figured out. I thought you mentioned that you had already checked the controls wiring.
