kill/start switch prob...im new
well the kill switch works but when i push the start button, the light turn off but nothing happens. it start with the solenoid but thats it, i have replaced it with another used one, and i dont want to fab up a non stock start switch. any suggestions??
1994 fzr 600, 9300 miles, d and d slip on.
Re: kill/start switch prob...im new
Kickstand down?
no and all the wires are hooked up
- kilika2
- 1000+ Posts
Have you tried starting in neutral?
I know you shouldn't have to but sometimes the planets align funny and swamp gas from venus explodes and the bike acts weird.
Chris.
Chris.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
well it starts with the solenoid just not the actuall switch
also what color wires go to the solenoid to make it start because i know there is four wires that go to the switch
- kilika2
- 1000+ Posts
This is in the wiki if you need it again.
Blue and red to starter relay,
Also going to the switch there is a blue wire that becomes unsoldered and usually causes headlight issues but I imagine it would cause starting issues too. But there is black blue and red to the starter switch. Hope that helps.
Chris.
Chris.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
would the stater relay cause it not to start with the switch but start with the solenoid
im wondering if i splice into the wire that starts the bike, and run it to the solenoid, will it burn anything up without going through a relay??
The "solenoid" IS your starter relay; the 'main relay' is part of the safety system that prevents you from cranking the engine over in gear with the clutch out and the sidestand down. I see no technical issues with bypassing the safety relay, but on your own head be it if you forget one day and the bike takes off down the street without you...
so would a switch from like radio shack work, my start switch spring broke so it sticks, until i get a new one
