Engine Rebuild 93FZR600
- 1993FZR600
need a little help on rebuild. Dose anyone have anything on where my piston heads are supposed 2 be. like left to right or right to left what one is topdead center?
93 FZR 600 on the table.
Re: Engine Rebuild 93FZR600
Each piston is at top dead center at least once every second rotation of the crankshaft. If you line up the flywheel marks with the crankcase split, #1 or #4 will be at topdead center.2xls wrote:need a little help on rebuild. Dose anyone have anything on where my piston heads are supposed 2 be. like left to right or right to left what one is topdead center?
The leftmost cylinder-nearest the flywheel-from the view of sitting on the bike is #1. The rightmost cylinder is #4. #2 and #3 are in between them.
