FZR600????
Posted: Thu Nov 04, 2010 9:48 pm
by pdean8
what Model is this? just curious, as its got the body kit of the 91-93 yet I'm told it's a 94. I live in Australia if that helps at all
Re: FZR600????
Posted: Thu Nov 04, 2010 9:59 pm
by thatkid
Certainly looks like a 91-92 production model but, mine (imported from Europe) has the same single headlamp nose cone, and is declared registered 1993. Maybe the US got them first.
Maybe like as guinea pigs, so Japan could supply the rest of the world with proper bikes ha.
jk
Re: FZR600????
Posted: Thu Nov 04, 2010 11:15 pm
by ragedigital
I do believe it is a 93, from what I can find, but I have never seen that color scheme on a single headlight before.
Here in the states, the single headlight FZR600s were 91-92.
Re: FZR600????
Posted: Fri Nov 05, 2010 9:12 am
by Target30
def a 94 color scheme, thats what mine looked like when i bought it, but like rage said, i've never seen it on a single headlight.
my bike, sorta
Re: FZR600????
Posted: Fri Nov 05, 2010 9:37 pm
by pdean8
is it possible that Australia got the YZF600 renamed to the FZR600R? isn't that a single headlamp?
Re: FZR600????
Posted: Fri Nov 05, 2010 11:07 pm
by thatkid
YZR600 and the FZR600R frames are aluminium, Your frame is FRZ600 & made of steel.
Like I said Japan used the States for testing purposes = We get better bikes LOL2
Re: FZR600????
Posted: Fri Nov 05, 2010 11:17 pm
FZR600R is a foxeye. Different than yours. Because the lines get blurred with these bikes there's an off chance that you have a 92 that was not titled and registered until 94. So people are thinking it's a 94 from that. There's another off chance that you guys got a special model. I do recall Europe (Germany, Belgium, etc) getting an FZR 1000 with a gunmetal frame instead of the natural aluminum. I've only seen one of those though.
Re: FZR600????
Posted: Fri Nov 05, 2010 11:59 pm
by pdean8
is there anyway I can check? like the VIN code or something like that
Re: FZR600????
Posted: Sat Nov 06, 2010 2:04 am
by snboarder113
The vin will be correct for the frame, its possible and probable that somebody switched up the body work tho.
Re: FZR600????
Posted: Sat Nov 06, 2010 9:34 am
by Rich
mawler wrote:YZR600 and the FZR600R frames are aluminium, Your frame is FRZ600 & made of steel.
Um, did you proof read your post at all? :) YZR600 never existed (YZR was two stroke and unobtainable). FZR600 never had an aluminum frame in any of its configurations. The YZF600 never had an aluminum frame either. And the rest of the world always gets the newest models first or equal to the USA. I don't consider a nose change to be a new model.
Re: FZR600????
Posted: Sat Nov 06, 2010 10:12 am
sweekster wrote:FZR600R is a foxeye. Different than yours. Because the lines get blurred with these bikes there's an off chance that you have a 92 that was not titled and registered until 94. So people are thinking it's a 94 from that. There's another off chance that you guys got a special model. I do recall Europe (Germany, Belgium, etc) getting an FZR 1000 with a gunmetal frame instead of the natural aluminum. I've only seen one of those though.
Guys,
The model year is meaningless outside of the country you are in, I have a1981 RD400 which does not exist outside of my homeland. It equates to a 1980 Canadian model which does not exist outside Canada but is a Daytona 1979 bike in US form. so what year is it 79? 80? 81?
Re: FZR600????
Posted: Sat Nov 06, 2010 11:04 am
by _Will_
The VIN systems were standardized in 1981 so the 10th character in the VIN will tell you the year. The reality is whatever your department of motor vehicles has it titles as is probably what you're stuck with, I don't see it being worth it to fight them to correct it. This is assuming that in Austraila they have the same systems, with the global
parts bins I'm assuming so
Re: FZR600????
Posted: Sat Nov 06, 2010 11:29 pm
by thatkid
Rich what can I say er..... I have fat fingers and made a typo My "R" key is directly above the "F" key lol. Thanks for the info on the frame material tho, I definitely thought the YZF600 and 600R foxeye frames were aluminium. :cheers:
But your wrong Japan does use the USA as guinea pigs, I discovered that a few months ago, one night I had a dream :grinnod: I'm jk again of course :)
Thanks for the frame info :thumbsup:
pdean8 wrote:is it possible that Australia got the YZF600 renamed to the FZR600R? isn't that a single headlamp?
Your frame is defiantly FZR600, The YZF600 and FZR600R foxeye frames look like this
Please correct me if im wrong :thumbsup:
Mal
Re: FZR600????
Posted: Sun Nov 07, 2010 12:08 am
by fzrbrandon
Hey guys,
I realize it's in Australia but that bike is exactly what would be the result if you married the black model of the U.S. '93 (as Darrin mentioned) - with the upper of a black model U.S. '92 (and took off the decals on the lowers of course).
