mszilves wrote:Hey guys,
I'm currently running 0.85kg/mm Racetech springs up front, and since most of my riding is street, I find it a bit stiff sometimes. I'm about 185lbs with full gear.
I'm curious for those of you that have the Progressive springs, how is the ride? Does it only come in one rate? Since the RaceTech's are not progressively would, I wonder how much of a difference that makes.
Let me know your experiences.
MSZ,
Pro-tech 0.85 kg/mm springs are linear rate (big bump/little bump it will react the same way.Unless you are running PD valves (cartridge Emulators they will appear to be too stiff as the stock oil settings and rebound system is not designed to work at 0.85 but at 0.46 <?>.
If you buy a set of either race tech emulators (169 USD + shipping ) or a set of YSSusa PDValves ( not sure what you would be quoted but is model 310 you should look for ) you will have a far superior ride I have both in 2 different bikes and they are a real joy (the SV rider club say it is a must just as we do about VR's <BG> ) Be aware the mod to the forks is PERMANENT unless you want to weld back holes and re-drill to close tolerance.
A word of WARNING here PD valves & cart emulators CANNOT be used properly with Progressive springs !!!!!!
Ok progressive springs are supposed to be stiff enough not to bottom out on big bumps and weak enough to smooth out little bumps.
The thing I found frustrating was that no-one would ever quote what the various spring rates incorporated in the progressive spring were.
So you had to rely on some spotty oink saturday kid on the sales desk giving you a progressive spring for your bike and even that over 5 different brands varied by 28% in one case I tested out. The lengths varied 10% wire diam was 16% variance according to my notes on that bike.
OK lecture done !!
now help the old man out here tell me:-
Either the O/D of the stock springs & their length
OR
the I/D of the fork tube and the spring length.
I had a chat with TWO spring making companies that specialise in prototype work and both said they are prepared to make fork springs to any spec (rear shocks as well) for approx 50UKP a pair in the case of fork springs and about 40ukp rear (this includes using their design team to figure out what is what )
Now considering the hell I have been thro for my linear springs (walletdraggers & RT +Ohlins + Maxton+ Hagaon etc ad nausium ) being so un helpful
) we now have another 2 sources of FZR springs YES
PLUS we can re-spring any rear shock we care to use RESULT
