Im looking to buy a FZR 600 motor and drop it into my FZR 400 chasis. My question is are there any big differences between a 90 fzr 600 motor and a 97 fzr 600 motor ? or are they basically the same ? what year would u recomend for me ?.
Do i have to run the air box with the carbs, can i use like k&n pod filters ? whats the good setup for the fzr 600 ? thanks guys.
FZR 600 90-97 MOTOR DIFFERENCES ?
Re: FZR 600 90-97 MOTOR DIFFERENCES ?
They are all basically the same. Main difference is that the VR changed around 95. You can even drop a YZF600 into that 400 frame.Fzrmike33 wrote:are there any big differences between a 90 fzr 600 motor and a 97 fzr 600 motor
Unless you have tuning skills and the necessary tools, stick with the stock air box. With a jet kit and a nice aftermarket exhaust, you can get a sweet sounding, smooth running FZR.Fzrmike33 wrote:Do i have to run the air box with the carbs, can i use like k&n pod filters ? whats the good setup for the fzr 600 ?
The yzf 600r motor same as FZR ? any benifit to using 600r ? been pricing motors and the FZR motor is much less in price.
In addition to the VR, the 89-91? FZR600 engine has a oil filter cartridge whereas the later years had a spin on oil filter.
voltage regulator
'92 FZR600
Lots of Powder
Lots of Powder
