I'm trying to figure out a way to mount my Nuvi 255w. I had a RAM brake reservoir mount kicking around but it hits the metal surround when the bars are turned.
Does anyone here use the RAM stem base? Part number: RAM-B-342U
last thing I want is a visual target that doesn't matter at all to the task at hand(actually riding).
I have a map on the top of my tankbag.
I cannot ride off the map between tanks, and my intermediate term memory is pretty good, so a good look at it whilst filling the tank is usually all I need to know where to go.
And, my radar detector(a useful electronic gadget) gives compass points.
I've seen people use them on more sport touring bikes like the Suzuki SV class and Yamaha FZ1/6 class because there is more room and your face isn't so close to the front of the bike.
There just isn't much room on the FZR other than maybe inside the windscreen at the top.
Good luck!
I made a custom mount for a buddy that runs in front of the tank cover and onto those two allen heads. It come up and splits and allows for a shelf to attach a softcase GPS case with clear front.
'96 FZR600
-Stainless brake lines, K&N Filter Pods, R6 front calipers, R6 Front and rear Master cylinder, Factory Pro Stg 1 Jetkit, R6 Headers (TK), '08 R6 Rear shock w/ adjustable dogbones (RR), Airtech R1 kit (and all the mods that go with that), Home made 5 d ignition advance, YZF600r D&D Modified short can with R6 mid pipe, Progressive rate front suspension, YZF600r Swingarm/wheel, 520 14/45, 47, 48 Sprockets, China's rearsets, YZF600r modified undertray, Cheap battery mod so I can run lay flat glass matts, And anything else I become compulsive enough to do to her...
-FOR SALE- *sniff sniff*
