Suggestions for rear turn signal mod?
vmaxmike
Post by vmaxmike »
Does anyone here have their rear fender cut (above where license plate would mount) YET STILL somehow UTILIZE the stock turn signals? I'd like to use the stock signals but am trying to avoid having to buy a replacement fender. Any suggestions on how this might be accomplished would be appreciated. Thanks
Dynastar12
Re: Suggestions for rear turn signal mod?
Post by Dynastar12 »
I drilled holes in the stock bracket under the subframe and relocated the stock signals. See below. The bracket helps to hold onto the stock fender/license plate mount if I remember correctly, but mine has been chopped down a bit as the back part of the fender was removed. I also utilized the bracket to relocate my license plate with the help of a couple other pieces of hardware from the local hardware store. I didn't need to drill any new holes for this. Wish I had a pic that was zoomed in a little more for you, but you'll get the idea. Hope this helps.
