Clutch Cable Length???
Does anybody know the length for the clutch cable? This is a 92 600 Thanks for your help
Re: Clutch Cable Length???
Whats the problem stretched? cannot find a replacement?lilevl wrote:Does anybody know the length for the clutch cable? This is a 92 600 Thanks for your help
I think it's stretched out a bit but I won't know forsure unless I know the exact length of what it should be
L,lilevl wrote:I think it's stretched out a bit but I won't know forsure unless I know the exact length of what it should be
experience says that if it is stretched to the point of not working you will see broken strands of the inner at the ends.
If you got those frayed ends bin it & buy another.
If the ends are sound then you need to re-adjust the clutch as per the manual.
