Well I noticed when riding tonight that the coolant temp light is out on the cluster, does anyone know what kind of bulb it is and how to get to it.
Thankyou
coolant light on cluster out
Re: coolant light on cluster out
There is no coolant temp light to my knowledge only Neutral, High Beam, Oil Level and Turn indicator. Those are all : http://www.ronayers.com/Search/N/687/Pa ... /Source/YA89fzr884 wrote:Well I noticed when riding tonight that the coolant temp light is out on the cluster, does anyone know what kind of bulb it is and how to get to it.
There might be a white light behind the coolant gauge, but I don't see the part for those. To my knowledge they were 1.7W bulbs.
darrin
The white illumination lamp is capless, in the UK it's a "12 VOLT 12v T10 3w 504 BULB LAMP 10mm (x10) - DASHBOARD"
The holder is a rubber push in type similar to these, which are the warning lamps.
EDIT I think in the states its this bulb or similar I'm not sure of the wattage though https://www.interlight.biz/light-bulb/194
