Help
Help
I was riding down the road at 55 and the bike lost all power at once. (1994 FZR) No lights,no horn no power period. I checked the fuses under the seat and all were good. Getting 12.4 volts at the battery. Any advice on where to start or what may be the problem. Thanks
Re: Help
The same thing happened to me. You probably blew the main fuse because of a ruined voltage regulator. The main fuse is under the left side of the tail plastics. If you have the pre-95 VR I would replace it as soon as possible with one from any YZF whether it is actually blown or not.
02 R6 Front End
Ducati M900 Seat/Taillight
Honda VFR750 Swingarm/Wheel
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
Re: Help
blensen wrote:The same thing happened to me. You probably blew the main fuse because of a ruined voltage regulator. The main fuse is under the left side of the tail plastics. If you have the pre-95 VR I would replace it as soon as possible with one from any YZF whether it is actually blown or not.
Thanks. Will check it out.
Re: Help
If the main fuse has blown, your VR is also fried, the VR WILL kill your electrics!!!!figman wrote:blensen wrote:The same thing happened to me. You probably blew the main fuse because of a ruined voltage regulator. The main fuse is under the left side of the tail plastics. If you have the pre-95 VR I would replace it as soon as possible with one from any YZF whether it is actually blown or not.
1. Replace the VR ASAP
2. Then replace the main fuse
Re: Help
mawler wrote:If the main fuse has blown, your VR is also fried, the VR WILL kill your electrics!!!!figman wrote:blensen wrote:The same thing happened to me. You probably blew the main fuse because of a ruined voltage regulator. The main fuse is under the left side of the tail plastics. If you have the pre-95 VR I would replace it as soon as possible with one from any YZF whether it is actually blown or not.
Will do. Thanks for the heads up.
Re: Help
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
