Front turn signals (Flush versus long stem)
Posted: Wed Aug 04, 2010 9:44 am
by vmaxmike
I notice some FZR's have the nice looking flush mounted front turn signals that integrate nicely rignt into the cowling but cant find that on the Yamaha microfiche. Microfiche only shows the long stem ones that stick out through the hole. Is this a stock or aftermarket item?? Where can I get these flushies?
Re: Front turn signals (Flush versus long stem)
Posted: Wed Aug 04, 2010 10:51 am
by delvryboy
Aftermarket = Ebay. Make sure you get dual filaments for the front: 3 wire.
Posted: Wed Aug 04, 2010 2:59 pm
by trifgeorge
i know that i'm a noob, but why dual filament?
Posted: Wed Aug 04, 2010 3:12 pm
by 4Rings6Stars
Dual filament bulbs (3 wire) allow you to use the front signals as running lights as well as blinkers. I believe there is also a mod that can be done to make the 2 wire, single filament bulbs work for this.
Posted: Wed Aug 04, 2010 4:00 pm
by Genesis
4Rings6Stars wrote:Dual filament bulbs (3 wire) allow you to use the front signals as running lights as well as blinkers. I believe there is also a mod that can be done to make the 2 wire, single filament bulbs work for this.
+1 Yes there is. pm me for info.
Posted: Thu Aug 05, 2010 2:49 am
by trifgeorge
Got it!:D thank for the answer
Posted: Thu Aug 05, 2010 9:53 am
by ragedigital
The only company, that I know of, that makes the pefect fitting flush mount turn signals is Flanders.
Look on page 76 - center bottom (white):
http://www.flandersco.com/Images/PDF/El ... atalog.pdf
