Electrical issues on my 92 600. Search says maybe VR?
Posted: Thu Jul 22, 2010 6:23 pm
Hi guys -
Just got the bike and trying to get her on the road.
Low beam was not working at all, but the high beam would work fine when switched on. Also, the tail lights were not working (and would work intermittently when I touched/moved the wires around). Tail light bulbs tested fine, but when I went to pull the headlight bulb out, the bulb glass is burned/bulging and the plug is melted and corroded. Is it possible that the bulb was not correct or is this an issue with the VR I have read about so many times in my searching?
A buddy of mine has a spare VR, but how about the plug--Is that a common, easily replaceable piece?
Also, what bulb should I run on the 92, single style headlight?
Here are a few pics of what I'm dealing with:
A few other shots of the electrical system. Note the cobbled together wiring in the back. I think this was due to aftermarket signals?
