Working on FUBARed 92 600 clutch. ANyone with intimate knowledge or a manual, (even the local dealer does not have one) help me with how close I am on the proper alignment of pieces in the photos? You can email me at ben.getz@recgroup.com also for further info/questions. Many thanks, and to Genesis who recommeded this site.
i though that peice was adjusted by the nut on the outside. that seems to be the orintation of the arm it basically just pushs the rod through the engine to disengage the cluch ie the threaded section. i would guess you thread the two peices together bolt it in then the cable comes threw the hole in the top then follow the clutch adjustment steps that are on here somewhere
