exhaust chop you tube sound
Posted: Mon Jul 12, 2010 10:12 am
after the tail swap the exhaust looked to long so i purchased a cheap stock exhaust to chop , i cut the end off with grinder, i then cut 150mm off ,i was lucky as this was the end of the baffles ,i then ground the baffles down to the inner flange, also grond the internal baffle on the end cap, i then welded the end cap back on , now it has a nice rumble sounds great and not to loud
http://www.youtube.com/watch?v=ducSN_rj17M
gallery2.php?g2_itemId=18868&g2_imageViewsIndex=1
