oil filter and oil
oil filter and oil
I know it has been beat to death but....
i am going to swing though the auto parts joint and get a new oil filter and some oil for the bike. i ran 20w50 full synthetic last time but the oil filter i got was wrong so i need to know do you guys know a part number or something where i can get a oil filter from the local auto parts store by chance
any cheap recomendations on oil as well (i have 8 bikes an all are getting new fluids today so i am not watning to go broke) my harley gets amsoil the rest get generic and run fine on that
http://www.thepowderpro.com
The Powder Pro
The Powder Pro
Re: oil filter and oil
well after some hunting
Oil filters that would work
• AC Delco PF1237
• Baldwin B1400
• Firestone TF2876
• Hastings LF113
• NAPA Gold 1365
• Purolator L14612
• STP S-02876
• WalMart SuperTech ST6607
• WIX 51365
Longer filters
• Fram Double Guard DG7317
• Fram PH7317
• Fram Tough Guard TG7317
• Fram Xtra Guard XG7317
• Group 7 V4610
• Group 7 V4620
• Hastings LF240
• Mighty M4612
• Motorcraft Long Life FL-821
• Napa FIL1356
• Napa Gold 1356
• Parts Plus PH2867
• Pennzoil PZ-109
• Penske 7317
• Powerflo SL14610
• Powerflo SL14620
• Pro Gauge PGO-4620
• Pro Tec 164
• Promotive PH4610
• Pronto PO3593A
• Purolator L14610
• Service Champ OF-4622
• Shell SH48
• Shell SH529
• Stp S-02867.
• Valvoline VO50
• Warner PH2867
• Wix 51356
Oil type: 20w50 or 20w40 if none avail 10w30 will work
Amount: 3 qts bike will hold 2.6 qts
Fork oil: 15oz per fork
Battery: walmart Champion PT# 12n12a4a1
• AC Delco PF1237
• Baldwin B1400
• Firestone TF2876
• Hastings LF113
• NAPA Gold 1365
• Purolator L14612
• STP S-02876
• WIX 51365
Longer filters
• Fram PH7317
• Group 7 V4610
• Group 7 V4620
• Hastings LF240
• Mighty M4612
• Napa FIL1356
• Napa Gold 1356
• Parts Plus PH2867
• Pennzoil PZ-109
• Penske 7317
• Powerflo SL14610
• Powerflo SL14620
• Pro Tec 164
• Promotive PH4610
• Pronto PO3593A
• Purolator L14610
• Shell SH48
• Shell SH529
• Stp S-02867.
• Valvoline VO50
• Warner PH2867
• Wix 51356
The Powder Pro
The Powder Pro
Or anything that will fit a 92 Mazda Miata... or can you click this ---> viewtopic.php?f=11&t=1001
NAPA/WIX (5)1365 does NOT work - at least not the current version!JRK5892 wrote:well after some hunting
• AC Delco PF1237
• Baldwin B1400
• Firestone TF2876
• Hastings LF113
• NAPA Gold 1365
http://www.fzrarchives.com/ipb/index.ph ... opic=50486
http://www.calsci.com/motorcycleinfo/Consumables.htmlThere are highly significant differences between different brands of oil filters. Most modern Japanese motorcycles use the same oil filter as the Mazda V-6. For the best protection in your bike, use Mobil-1 M1-108 / M1-110 oil filters, $12 at AutoZone; or Purolator Pure One PL14612 / PL14610 filters, about $6 at Pep Boys. Next best, use Bosch 3300 / 3323 filters, about $6 at AutoZone, or SuperTech ST7317, about $2 at Wal-Mart.
The list of oil filters is in the WIKIJRK5892 wrote:I know it has been beat to death but....
I use the m1-108. Same filter as my car: '06 Subaru Legacy, non-turbo.
'92 FZR600
Lots of Powder
Lots of Powder
- kilika2
- 1000+ Posts
I use the purolator L14612 or pl it the same filter capacity as kn but half the cost. Then I use castrol semi-synthetic 10w40. No problems so far for me.
Chris.
Chris.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
Use diesel engine oil, of the correct grade. Unlike petrol oil it has less of these friction modifying witchcraft chemicals, so you can go synth without clutch slippage, for far less than the cost of specialist bike oils.
Same here, I use Rotella and love it.Fartblood wrote:Use diesel engine oil, of the correct grade. Unlike petrol oil it has less of these friction modifying witchcraft chemicals, so you can go synth without clutch slippage, for far less than the cost of specialist bike oils.
i ran castrol semi-synthetic 10w40 on my first change and hated what it did, had such bad slipage on the clutch... so bad that i pulled the plate to inspect them... no problem at all, so i used what oil was left when i put it all back together and still had the slip... did not even think of the oil on the wet clutch! but when i swapped to Vavoline high milage semi synthetic it was like a whole new bike! so much so that my wife asked me if i replaced the clutch in it when she took it out yesterday. but i did learn a lesson... DO NOT USE A WIX FILTER!
The Powder Pro
The Powder Pro
Jeez, reading the replies would have helped, wouldn't it? I did warn ya...JRK5892 wrote:i ran castrol semi-synthetic 10w40 on my first change and hated what it did, had such bad slipage on the clutch... so bad that i pulled the plate to inspect them... no problem at all, so i used what oil was left when i put it all back together and still had the slip... did not even think of the oil on the wet clutch! but when i swapped to Vavoline high milage semi synthetic it was like a whole new bike! so much so that my wife asked me if i replaced the clutch in it when she took it out yesterday. but i did learn a lesson... DO NOT USE A WIX FILTER!
[quote="ranmafan" Jeez, reading the replies would have helped, wouldn't it? I did warn ya...[/quote]
R,
do not be suprised that advice freely given is ignored, most people think " free=useless "
R,
not at all, when i read your post i had already had it on the bike and the oil was finished up... actaully i read it while at the shop and that made me go out an look at the bike to find the oil all over... would nto call that ignoring ya
The Powder Pro
The Powder Pro
Well, at least I can be sure it's not just some weird Canadian version of the NAPA/WIX filter not sealing well.JRK5892 wrote:not at all, when i read your post i had already had it on the bike and the oil was finished up... actaully i read it while at the shop and that made me go out an look at the bike to find the oil all over... would nto call that ignoring ya
Btw, NAPA actually sells the Bosch filters, as well (p/n RB3300), which is what I ended up using. FRAM? I'd rather skip a few oil changes...
ha ha ha so i hear, it is cool man thanks for the tip!
The Powder Pro
The Powder Pro
