long time reader first time writer help
gorman8523
Post by gorman8523 »
94 fzr 600 my first bike so all new to me but heres problem since i have had the bike if i let off the throttle all the way it dies but lived with it anyway went for my first good ride and while rideing started missing a little so i changed the plugs while changeing them messed with the plug wires (which should have nothing to do with my now problem) and road the bike lastnight and noticed my lights where dimming up and down but then straitened out but when i stopped the bike shut down i mean everything lights whole nine yards and wouldnt restart then got pissed and slaped the handle bars to the right and everything came back on and it started but does it everytime i stop please any thoughts or point me in the right direction thanks
cad600
Re: long time reader first time writer help
Post by cad600 »
Well, your carbs need some work.
But to your new problem, you need to sort out some electrical issues. First place to start is the "start" switch. Make sure you don't have any wires grounding out on the frame or radiator. You probably also need a new VR.
Best bet is to get a service manual and go through the trouble shooting section.
sweekster
Post by sweekster »
Agreed
Time for carb cleaning and synch. We have a charging system flow chart in the wiki.
All of the above.
There is a known problem with the right hand switch gear going AWOL on you. It is well covered in the old mails
The hassle is that the problem drains your battery puts too much strain on the old style VoltRegulators which fry and take out your fuses and electronics.
The first thing is to put the battery to charge & make sure the liquid level in it is correct. Check your fuses (make sure the connectors are all clean. Fix that right hand switch gear, put everything back turn the ignition , hear the fuel pump charge the carbs and then try starting the bike test the voltage to the battery at 3K RPM should be 13.8 or there abouts anthing more than 14+ and your VR is gone or going to fry. IF it is higher replace it with a VR from a R6
& do not use the bike before you replace it !!!(detail of all the checks are in the WIKI as is the HOW to replace your VR .
pefrey
Level 5.5
Level 5.5
Post by pefrey »
Feel free to sprinkle a few of these in your post.
haro504
Level 7.5
Level 7.5
Post by haro504 »
periods are the devil they make women moody and vengfull thats why i never use them i also refuse to spell correctly
