fzr 600 carbs
Posted: Wed Jun 16, 2010 3:03 am
by tony
my fzr has 35k on clocks i believe the needle wears making it erratic on low revs ,i am taking airbox off and replacing with four k and n filters and 110mm main jet,i am in uk at sea level ,i am not racing ,any advice appreciated
Re: fzr 600 carbs
Posted: Wed Jun 16, 2010 5:44 am
tony wrote:my fzr has 35k on clocks i believe the needle wears making it erratic on low revs ,i am taking airbox off and replacing with four k and n filters and 110mm main jet,i am in uk at sea level ,i am not racing ,any advice appreciated
Tony,
If you have worn needle jets (emulsion tubes) you need to replace them
Taking off the air box and using individual pods is going to make you do an awful lot of carb tuning UNLESS you read up the "tuned length air inlet trick" and then follow thro on it, will save you a lot of faffing with the carbs
DO NOT change any jets until you do the trick or you will spend your life "carb tweeking" and NOT riding the bike. :headscratch:
Your call !
OH yeh put your location in the personal profile area or no one will remember your a Brit ! :cheers:
Brit bikes are different to the US & Euro models in a lot of detailed ways :thumbsup:
Re: fzr 600 carbs
Posted: Wed Jun 16, 2010 5:59 am
by tony
thanks george how do i find how to do air intake trick
Re: fzr 600 carbs
Posted: Wed Jun 16, 2010 6:39 am
tony wrote:thanks George how do i find how to do air intake trick
This site has TWO wonderful facilities SEARCH & the WIKI {especially the Tech Book & Links page [written by some old Geezer who seems to have been around forever]} they really are your friends :whistle
Re: fzr 600 carbs
Posted: Wed Jun 16, 2010 9:22 am
by tony
cheers george this is the article i read from the wiki As by magic no more hole in the power band!!!! running #110 mains, 2, 1/2 turns out on mixture, stock end can!i am stripping bike at weekend i will take pictures of progress im doing fork seals ,removing airbox /putting pods on ,moving expansion bottle to under tank cover and cutting tailpiece
Re: fzr 600 carbs
Posted: Wed Jun 16, 2010 12:45 pm
tony wrote:cheers George this is the article i read from the wiki As by magic no more hole in the power band!!!! running #110 mains, 2, 1/2 turns out on mixture, stock end can!i am stripping bike at weekend i will take pictures of progress im doing fork seals ,removing airbox /putting pods on ,moving expansion bottle to under tank cover and cutting tailpiece
Happy tweaking :-}
