Bike won't shift from 4-6 gears
boweracing0
Post by boweracing0 »
Was wondering if anyone had any idea what could be wrong NEW to the bikes.... I have a 1992 FZR600.... Goes from 1-3 good won't shift from 3rd to 4th.... Also is the oil filter the same from 87 to 92....Thanks
Fizzinatorr
Level 6.5
Level 6.5
Re: Bike won't shift from 4-6 gears
Post by Fizzinatorr »
boweracing0 wrote:Also is the oil filter the same from 87 to 92....
nope
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
Are you in the states?
The FZR600 was produced in 1989, so 87-88 would probably be an FZ600.
IIRC, only the 89 and 90 models had a cartridge filter. From 91+, they switched to a spin-on filter.
As far as your shifting goes, you may have an issue with a shift fork. Might want to check the Service Manual.
boweracing0
got it....its the paper filter kind..thanks
boweracing0
it needs a clutch cable could...guy i bought it from has a bolt holding the cable in at the handle... It goes into 123...but not 456 any ideas...thanks
Post by thatkid »
boweracing0 wrote:it needs a clutch cable could...guy i bought it from has a bolt holding the cable in at the handle... It goes into 123...but not 456 any ideas...thanks
Since your new to bikes. Could I suggest you give a more informative description of the symptoms, how long have you owned the bike? have gears 456 ever been usable? and purchase a manual. I'm guessing the bolt is at the pivot on the clutch lever, which is normal.
1. You mean while riding?
2. Have you tried going through all the gears while the bike is at a standstill? Sit on the bike walk the bike back and forth, try to engage the gears. Try that with the engine running and again without the engine running, and obviously using the clutch.
Hopefully it is the clutch cable or poor adjustment. Could also be the wrong grade of oil, and as mention "a shift fork" issue.
Good luck.
haro504
Level 7.5
Level 7.5
Post by haro504 »
you can actually shift without even pulling in the clutch so i doubt that the cable is the problem. there was a guy here whose clutch plates were stuck together and draging so it wasent shifting right but if its not even going into the gears id say its more of a trans problem (shift forks or drum). is it staying in 3rd when tring to shift or is there nothing at all
Post by thatkid »
You cant shift gears at a standstill without the clutch, while riding you can. I was trying to identify if it was the clutch or not. nothing more.
haro504
Level 7.5
Level 7.5
Post by haro504 »
oh i wasent refering to your post hahaha i can see how youd think that though i was just tring to help narrow down the problem. i was just refering to that i dont think the cable had any effect on the situation unless the other safty switches were faulty but then it wouldent turn over then. sorry about that
boweracing0
I rode it today and all gears work 1-6 from 456 i didnt use the clutch and it worked but if you tried to use the clutch it would go in gear...thanks for the replys guys
haro504
Level 7.5
Level 7.5
Post by haro504 »
it would or wouldent go into gear with the clutch? if it doesent then you probally wanna make sure the cable is adjusted right and take the clutch pack apart to make sure everything is ok
Kyle844
100+ Posts
100+ Posts
Post by Kyle844 »
I had a similar problem but my shift lever was corroded onto the peg so when shifting the whole peg would rotate up or down which meant you'd have to move your foot to bring the lever back down to its original position, that was half my problem, broke it loose and cleaned it up and lubed it, now the lever moves and the footpeg is secure in one position. the other half was the shift linkage wasn't in the correct position on the splined rod coming out of the trans, a little trial and error and lots of lubrication and it shifts through all the gears perfect! Don't always assume its the worst and tear apart something if you don't have too =]
-96 FZR 600 streetfighter full carbon fiber wrap.
-77 Chevy Nova viper red drag car.
