FAT front wheel axle modification/upgrade... ???
Posted: Thu May 13, 2010 5:35 am
Hi !
I'm looking for a "How To" make a FAT Front Wheel Axle modification tread as yamaha_george described.
Maybee some one can write one up and put it in the WIKI / FAQ / FZR-600 section ???????
I really want to do this mod for my FZR600
yamaha_george wrote: However a front fork brace will not cure the problem of your tyre cupping
(tyre cupping has been discussed before).
The solution is a bigger diameter front axle (this is discussed on the forum & parts (bearings) are listed ).
How do I know this works ?
Eric Buell (Ex. Buel Motors) & I back In the early '80's were discusing bits & bobs to do with stability and ridabilty of one of my race bikes.
His solution to my high speed weave problem was to reduce front shock flex.
With a wimpy size axle (back in the day it was 15mm) allowed the two front shocks to work independantly of each other as the
axle flexed under load we are talking 90mph with knee down & a very nerve wracking back end wiggle.
What I did was replace the 15mm axle with 25mm axle ( I was lucky the bearings were the same O/D ) the corners I used to testing went
from 90 mph to 125 & 130mph and the bike tracked as though on rails
I was gone so long testing grinning like a jackal that my mechanic had closed the shop early to come and find out if I was ok.
I let him have the bike and he was out for an hour and had trouble taking his helmet off past the grin.
Needless to say he wanted a new set up to.
If you look at fast state of the art bikes (Ducati's ) they have massive front axle tubes (part of the size is required because it is a tube axle).
Please take a look at the idea as no one so far has had the facility to do it on an FZR-600
(myself included as my friendly neighbourhood machine shop boss retired earlier this year.)
91fzr600r wrote:yamaha_george makes a vary good point about the axle .
I will be doing this axle mod as well as the fork brace.
He said the axle flexed under load, we are talking 90mph with knee down & a very nerve wracking back end wiggle.....
mine was doing the exact same thing so i also installed a GPR stabilizer designed for a Kawasaki ZX6R (2006).
It helped with the wobble...
I will do the axle mod in a few weeks when I tare down my front end to inspect & replace headset bearings, fork seals & do a general tune up.
yamaha_george wrote:The NEW bearing sizes for the bigger front axle are already in the WIKI.
HOWEVER I have not checked how much "meat" there is in the bottom of the fork where the damper rod Allen head bolt goes.
You will need to bore out or remake the wheels internal spacer and the two wheel side spacers.
Please be aware that the wheel internal spacer is a high accuracy piece as far as length is concerned.
As a personal request as Site Director & one of the WIKI keepers PLEASE document with dimensions & part numbers plus the usual request for lots of pictures.
There is no need to write this stuff up your self in the WIKI if you send plain text & pictures to me I will WIKI'ize the deal for you.
E-mail me at: george@saltmine.org.uk if you need any help or advice.
91fzr600r wrote:yamaha_george,
I checked out lower shock tubes.... there's not enuff materal on the left (cluch side) shock tube.
yamaha_george wrote:Thanks for heads up,
but I know away round it !
yamaha_george wrote: When you say the clutch side leg, that has no thread for the axle in it right ?
So leave the diam of the axle the same that side but make it longer and thread the bit that sticks out.
The fat axle bit slides in from the right and the shoulder (ie the difference between diameters butts up hard to the left hand fork leg and is secured by the axle lock nut.
As an experiment I would make a sleeve that went over the original axle and thro the right hand fork leg & the wheel right up to the LH leg.
The benefit of this is a sleeve is cheap to make (compared to an axle (unless you are just turning down another bikes axle & threading it for your needs))
Also getting a sleeve lenght right to:-
a} get the wheel centered
b} cinched to the right torque without locking the bearings will be easier.
c} If the results are not better than the original handling you have not "lost" any parts in the process
haro504 wrote:I dont know what the FZR600 axel is but the diameter of the YZF600R (FoxEye) is about 17mm.
