HEADLIGHTS don't work...
Posted: Thu May 06, 2010 8:13 pm
by tbnj
ok so the bike was working fine... i washed it and the headlights won't turn on and neither will the lights on the speedometer... any idea? the 20a fuse that says head is fine
Re: HEADLIGHTS don't work...
Posted: Thu May 06, 2010 9:46 pm
by tbnj
i jumped the wire from the battery right to the headlight and the speedometer lit up, as well as the bulb.. could the problem be anywhere or should it be in my starter switch?
Posted: Thu May 06, 2010 9:52 pm
Might want to check the headlight switch. The blue wire in there is known for coming off.
Posted: Thu May 06, 2010 11:19 pm
by tbnj
as in the high/lowbeam switch? there is a series of wires running from the headlight that have a blue connector piece... i took that apart and cleaned the little bit of corrosion that was on there but nothing came of it
Posted: Thu May 06, 2010 11:29 pm
by shredex
tbnj wrote:as in the high/lowbeam switch? there is a series of wires running from the headlight that have a blue connector piece... i took that apart and cleaned the little bit of corrosion that was on there but nothing came of it
the little switch that turns low to high beam. Water got in mine and when I turned on my bike it just fried and melted the little button switch thing so I had to replace it....also, make sure you checked ALL the fuses.
Posted: Thu May 06, 2010 11:38 pm
by tbnj
ok i'll check it, but when i jumped the connection from the headlights to battery, i played with the high low switch and it worked
Posted: Fri May 07, 2010 7:59 am
by zero9243
for me I had to take apart the right controls (with the start button) and there was a wire in there that was loose that needed to be resoldered. I'd check in there too. Should be a blue wire.
Posted: Sat May 08, 2010 3:45 pm
by reallyniceguy
zero9243 wrote:for me I had to take apart the right controls (with the start button) and there was a wire in there that was loose that needed to be resoldered. I'd check in there too. Should be a blue wire.
Yup I had the EXACT same issue. it was the starting switch, it was bad. I noticed that sometimes the starter stayed stuck lol
but yeah the blue wire, if its disconnected or faulty switch it will not make contact and no headlight.
