89 FZR 600/ R6 front caliper conversion
Anyone have info on upgrading this single piston front end to the much improved 99-02 R6 front calipers? The 89 bolt pattern is the same as 86-88 FZ600 lowers. Not sure if later FZR models were equiped the same.
Re: 89 FZR 600/ R6 front caliper conversion
yeap the blue dots are bolt on
My FZR6 Rebuild
My FZR6 Rebuild
I thought the blue dots are direct bolt on for the dual pistons and not the single ones, I could be wrong though.
89 FZR 4/600- Chopped and fightered out, r6 header mod w/ Micron can
02 r6 front master cylinder/calipers & SS lines, 02 r6 clutch perch, 03 R1 front end, works performance rear shock. Its a work in progress still.
YUP that is my memory too that '90 onwards had 4 pucks and are thus Blue Spot swaps.JohnnyO wrote:I thought the blue dots are direct bolt on for the dual pistons and not the single ones, I could be wrong though.
89 forks will not be bolt on with the blue dots. They only use single pot and the bolt distance is different.
Upgrades:
on my 95 i used the blue dot ones... they worked great! since i had to rebuild them anyway i powdered them gloss black while i had them apart... for the front brake master i used a CBR master with adjustable lever...again tore that down and powdered it as well
got them and the braided lines for $30 on ebay
http://www.thepowderpro.com
The Powder Pro
The Powder Pro
If you are good fabricator then adapters can be made to allow for the 4 pot calipers. Otherwise a full set of 90+ forks or fork lowers is the way to go.
Cool, thanks for the feedback. I can fabricate a bracket - just looking for an easy way out. I was given the forks and are already bolted on - hate to buy just the lowers AND the calipers. I can deal with the bracket. Thanks again and sweet ride you got there, JRK.
