I have a problem with my bike that is driving me crazy. I was riding the other day and went to get gas stopped the bike and went to start it again and it would not start. No Head lights but is had all other electrical. I followed the post and attempted to clean out the Start switch, which was sticking but I had not issue with up until then, and still nothing. When I turn the ignition switch on again all lights come on neutral switch light, turn signals....still no head lights. I turn the Run switch on and I can hear a click in the REGULATOR RECTIFIER (which I though about replacing) and see a slight up tick on the Tachometer but nothing else....so you know I have replaced the battery with a new one which I have on a trickle charger and even tested the old battery and that should 12.8v, so I figured that is not the issue.
Please help I am not that knowledgeable when it comes to bikes!
Thanks in advance!
CJ
If you like you can e-mail me at cjcuprill@verizon.net
