How can i make this stand work?
so i picked this up last night for $20... could not pass it up! my swing arm does not have the bolts for it... any ideas on how i can make this work? Does anyone have this style of lift, if so how did you make it work?
http://www.thepowderpro.com
The Powder Pro
The Powder Pro
Re: How can i make this stand work?
JRK5892 wrote:so i picked this up last night for $20... could not pass it up! my swing arm does not have the bolts for it... any ideas on how i can make this work? Does anyone have this style of lift, if so how did you make it work?
See:-
http://www.saltmine.org.uk/kgb/yp7.html
for the basics :-}
- Fizzinatorr
- Level 6.5
you need spools
or you can find a way to attach paddles and lift your fizz up by the swingarm, you'd have to space it out i had one like it years ago
spools... i dont need no stinking spools
here is how i did it
to make the sport bike lift work, i counter sunk a piece of alum angle bracket, then threaded the foot of the lift, dropped a hardened allen head into that sucker to hold it, then ran a hardened bolt thought that, spun the head of the bolt on the grinder to make it go away, used fender washers to sandwich it to the old spool holders, ran the both through the angle bracket and capped it with another nut... solid as ever and works perfect! best part is, to use on a spool style all i have to do is remove the nut
here she waits
here she waits
The Powder Pro
The Powder Pro
JRK,
neat no mod to the bike & NO burnt paint .
Would you mind adding the pics to a quick WIKI HOW-To:-
Thank Y_G
Thank Y_G
done!
The Powder Pro
The Powder Pro
JRK,JRK5892 wrote:done!
Thank you on behalf of all who come after us <BG>
Y-G
