YZF fork swap
Posted: Wed Apr 07, 2010 9:40 am
by Newbee
Has anyone done a yzf fork swap, I looked in the wiki and all I saw was for the R6.
I also tried a search and came up with nothing.
I'm just looking at my options, I found some 98 forks for cheap.
Thanks for your help
Re: YZF fork swap
Posted: Wed Apr 07, 2010 10:45 am
Newbee wrote:Has anyone done a yzf fork swap, I looked in the wiki and all I saw was for the R6.
NB
Some one has done this for almost certainty., BUT you will need the triple tree & forks may be even the wheel to make it all work.
see what you mean with the search TOO common words '98 , YZF, fork , swap
Re: YZF fork swap
Posted: Wed Apr 07, 2010 11:17 am
If you can get the whole front end (that means EVERYTHING) then it's complete bolt on swap . Only thing is you'll lose the functionality of your speedo. The YZF speedo isn't cable/gear driven like the FZR.
Re: YZF fork swap
Posted: Wed Apr 07, 2010 1:52 pm
by Newbee
Ok, but what about the YZF600r forks, is the speedo cable driven or is it like the YZF-6R?
I would like to change up the front end but I dont want to change springs, oil and emulators.
Re: YZF fork swap
Posted: Wed Apr 07, 2010 1:55 pm
by shredex
Newbee wrote:Ok, but what about the YZF600r forks, is the speedo cable driven or is it like the YZF-6R?
cable
Re: YZF fork swap
Posted: Wed Apr 07, 2010 3:34 pm
by cad600
sweekster wrote:The YZF speedo isn't cable/gear driven like the FZR.
HOLY COW..... Sweekster got one wrong. Sorry, couldn't resist. It is the only time I've seen it happen - I usually look for post by you to check my own thinking. The YZF600 is in fact cable driven just like the FZR600. The R6 is the one that is digital.
I'd even bet that it will have the same spin rate making the speedo correct. But I'm just guessing on that part.
Re: YZF fork swap
Posted: Wed Apr 07, 2010 3:41 pm
cad600 wrote: HOLY COW..... Sweekster got one wrong. Sorry, couldn't resist. It is the only time I've seen it happen - I usually look for post by you to check my own thinking. The YZF600 is in fact cable driven just like the FZR600. The R6 is the one that is digital.
Well Superman has to take his cape off every now and then :rofl: . Yeah Cad's right on that one. The speedo is cable driven.
Re: YZF fork swap
Posted: Wed Apr 07, 2010 4:14 pm
by pefrey
You only said that the YZF was not cable driven, not which YZF. Perhaps you were talking about the R6 which then, you would be correct.
Re: YZF fork swap
Posted: Wed Apr 07, 2010 4:25 pm
by haro504
youll need the whole front end but it does bolt in i got one from mszilves goes right in but i dont think much if anything swaps from fzr to yzf600r except maybe the brakes. i got it for a build so i dident try
Re: YZF fork swap
Posted: Wed Apr 07, 2010 4:27 pm
cad600 wrote:
ALL Yamaha cable speedo drives have the same ratio
Re: YZF fork swap
Posted: Wed Apr 07, 2010 4:37 pm
pefrey wrote: You only said that the YZF was not cable driven, not which YZF. Perhaps you were talking about the R6 which then, you would be correct.
I was talking about the YZF600r (Not R6) so yeah I was wrong
Re: YZF fork swap
Posted: Sun Sep 05, 2010 1:48 pm
by Bratman3401
I just did a yzf front end swap not R6 and it is cable but it isnt working right idk whats wrong.... someone help.
