valve lifters
Posted: Fri Apr 02, 2010 4:57 pm
by lennyz600
so im in the process of putting my '89 back together and the vavle lifters got all jumbled up, so i have no clue which lifter goes with what valve. how screwed am i? from what im told im up the creek. priced new lifters and had a heartattack. any advice?
Re: valve lifters
Posted: Sat Apr 03, 2010 7:46 am
by reelrazor
you talking the shims? Or the buckets?
Eitherway you are going to have to install them, install teh cams and use a feeler gauge to check clearances and remove the cams and adjust accordingly.
Not screwed....or needing to buy new ones...just have a bunch more work than if you had them organized
Re: valve lifters
Posted: Sat Apr 03, 2010 9:26 am
reelrazor wrote:you talking the shims? Or the buckets?
As always RR is on the ball, here is the link to the WIKI how to:-
http://fzronline.com/wiki/doku.php?id=h ... clearances
& the clearance calculator program how to:-
http://fzronline.com/wiki/doku.php?id=shimswap
the actual prog :-
http://www.logicminds.biz/motorcycles/shimulator.html
