tampaFZR600
Level 4.0
Level 4.0
Post by tampaFZR600 »
Delete me
sweekster
Re: The LAST jetting question i SWEAR!
Post by sweekster »
Still haven't synched the carbs yet, huh? :whistle
shredex
Post by shredex »
sweekster wrote:Still haven't synched the carbs yet, huh? :whistle
tisk tisk, and to think I gave him welding tips for the job too. lol
tampaFZR600
Level 4.0
Level 4.0
ff
Lean at idle, staggering rich @ mid-throttle. :dubious: Welcome to the joys of carb tuning. banghead
Have you set your float heights?
Re: The LAST jetting question i SWEAR! yes you will swear a lot jetting is a PITA .
How much of achange did you make with the main jets.
Adding an OEM replacement K&N will not effect the tune the shorty pipe may do. Xan you get back to stock pipe and get abase line to work with from there?
tampaFZR600
Level 4.0
Level 4.0
sweekster
Post by sweekster »
Did you change JUST the mains? Do you have adjustable needles?
tampaFZR600
Level 4.0
Level 4.0
^^yes they are adjustable needles, 6 settings, i started at 5th from top, now at 3rd. It's a DJ kit
tampaFZR600
Level 4.0
Level 4.0
woooooopppddeeeee freeeeeeeggginnnn dooooo!
tampaFZR600 wrote:woooooopppddeeeee freeeeeeeggginnnn dooooo!
I guess from that yell you have ironed out your problem?
tampaFZR600
Level 4.0
Level 4.0
tampaFZR600 wrote:no actually it runs GREAT until you get to about 3/4 throttle, then it breaks up and loses all power
If you take out the mains entirely will it do the same bog out at 3/4 throttle if so you are too rich if not then you are too lean.
If you pull your mains and it DOESN'T run like a bag of smashed assholes, your nozzles / needle jets are too small. Or your fuel level is WAY too low. Or both.
tampaFZR600
Level 4.0
Level 4.0
DonTZ125 wrote:If you pull your mains and it DOESN'T run like a bag of smashed assholes, your nozzles / needle jets are too small. Or your fuel level is WAY too low. Or both.
