89 fzr600 wiring harness work in a 93 fzr600
Posted: Mon Mar 29, 2010 8:40 pm
by burns556
hey guys just wondering if the 89 harnessnwill work in a 93 po hacked up cut and shorted out the harness in it thanks
Re: 89 fzr600 wiring harness work in a 93 fzr600
Posted: Tue Mar 30, 2010 1:44 pm
by cad600
Short answer is NO. BUT if you have EVERYTHING then yes it will.
Th VR is the same so it should clip straight on. But the Fuse block is different so you will need them (the 89/90 has the main fuse separate). There may also be differences with the gauge and headlight / turn signal wires, but I can't remember that part any more.
