89 fzr600 wiring harness work in a 93 fzr600
burns556
100+ Posts
100+ Posts
Post by burns556 »
hey guys just wondering if the 89 harnessnwill work in a 93 po hacked up cut and shorted out the harness in it thanks
i like cookies nom nom
cad600
Re: 89 fzr600 wiring harness work in a 93 fzr600
Post by cad600 »
Short answer is NO. BUT if you have EVERYTHING then yes it will.
Th VR is the same so it should clip straight on. But the Fuse block is different so you will need them (the 89/90 has the main fuse separate). There may also be differences with the gauge and headlight / turn signal wires, but I can't remember that part any more.
