piston problems
Posted: Sat Jun 14, 2008 5:08 pm
by supa600
does anyone know how to tell if your rings are bad ? my bike is smoking and rage and I took it apart today, looks like a screwed up head gasket(homemade) ,cylinder walls look fine ....any help would be great !!!! thanks...
Re: piston problems
Posted: Sat Jun 14, 2008 5:10 pm
by R3TARD
put it all back together and get a compression test kit and test teh compression on each cylinder. I'm not sure on the specs I think if your over 120 you are ok.
Re: piston problems
Posted: Sat Jun 14, 2008 5:12 pm
by supa600
we already did the test and I was at 160 psi ,,with wiesco pistons , should I have burns on the walls or scars or movement in the pistons when there all the way up ?
Re: piston problems
Posted: Sat Jun 14, 2008 5:24 pm
by R3TARD
160 is great. Burn marks? maybe without scoring but if there is any scoring i would retest for compression because gouges (scoring, or scars) on the cylinder walls is no good man.
Re: piston problems
Posted: Sat Jun 14, 2008 5:32 pm
by supa600
there isnt any scoring ,but there is little movement when the two outside cylinders are all the way up ,I think the headgasket is my problem ,it looks like the previous owner made it in shop class,does anyone have a pic of a new one ?
Re: piston problems
Posted: Sat Jun 14, 2008 11:05 pm
by R3TARD
replace it and see I wouldnt worry about the pistons If there is no scoring the rings and pistons do have a minute amount of play in them
