Page 1 of 2
Blinker issues, HELP!
Posted: Mon Mar 15, 2010 10:50 am
by Newbee
I have a 93 fzr600
The Blinkers have been working fine until last week, nothing changed.
No matter which way I turn on the signals both front flash and nothing from the back, I can hear the tick out of the signal box, it seems kinda loud.
I have checked all the fuses and all are fine.
I've tried screwing around with the wiring but I cant see anything wrong???
Is there a chance the turn signal box has gone bad?
Any help would be appreciated.
Re: Blinker issues, HELP!
Posted: Wed Mar 17, 2010 3:11 am
by Dragon
Check your bulbs...
Posted: Wed Mar 17, 2010 12:07 pm
by Newbee
I took the blinkers off and tested them on my wifes bike, they work fine.
Still looking for help.
Posted: Wed Mar 17, 2010 1:57 pm
by Dragon
Is there power coming from both rear signal wires?
Check the connections for both sides while the signals are attached, after testing for power for proper connection. ( clean & put some electrical grease on them)
I would say the signal relay is fine because the front signals are working. It's got to be something with those wires for the rear...
Posted: Fri Mar 19, 2010 8:44 am
by Newbee
When I put the blinkers back on my bike, they worked for a second, then the bulbs blew. I picked up a second pair of blinkers yesterday, installed them and they worked for about 15 min, then the same issue, both the bulbs blew again???
Could it be a ground issue, or could my LED blinkers in the front be causing a problem?
Posted: Fri Mar 19, 2010 9:34 am
Newbee wrote:When I put the blinkers back on my bike, they worked for a second, then the bulbs blew. I picked up a second pair of blinkers yesterday, installed them and they worked for about 15 min, then the same issue, both the bulbs blew again???
N,
you have an imbalance in the original circuit which is meant for bulbs all round. The combined load of two bulbs sets the blink rate .
If you then replace the front set with LED's the whole thing is unbalanced putting more thro the bulb than the bulb is built for which is why they blow.
You have two choices
revert to bulds all round and keep the original solonoid(winker) asssembly
OR
put LED's all round and buying a solenoid/ winker block designed for LED's
for sources of electronic winkers for LEDs see EBAY
Posted: Fri Mar 19, 2010 2:21 pm
by Newbee
Thanks Yamha George
I guess I will have to get some LED's for the rear and a winker block for LED's.
Thanks for all the help, I love this forum there are so many years of experience combined here.
I'll let you all know what the outcome is.
Posted: Fri Mar 19, 2010 5:04 pm
Newbee wrote:Thanks Yamha George
Cool, this place is keeping me sane in the stupidity of what is going on here in the Windies.
Posted: Wed Mar 24, 2010 9:04 pm
by Fizzinatorr
You all resolved?
I have a few more ideas if you're not fixed yet
Posted: Thu Mar 25, 2010 8:00 am
by Newbee
I picked up some standard blinkers yesterday but I haven't had a chance to install them yet, I think Im just going to use standard blinkers instaead of LED's.
I'll let you guys know.
Posted: Tue Mar 30, 2010 1:02 pm
by Newbee
Ok, I installed the new front and rear blinkers..whala, teh signals work again.
They still blink irregularly when at idle, but when I bring the bike above 3k (rpm) they slow down to normal.
Any ideas?
Ground issue?
I checked all the connections and added electrical lube (no I didnt use KY).
Let me know what you think.
Posted: Thu Apr 01, 2010 6:13 am
Newbee wrote:Ok, I installed the new front and rear blinkers..whala, teh signals work again.
Any ideas?
Ground issue?
NB,
Check the bulb wattages and what is written on the relay sounds like there is a slight mic-match put the info up here and we can check it out.(check all 4 bulbs do NOT take it as given that all four are the same !
Posted: Sun Apr 04, 2010 10:44 pm
by Brutal Tooth
hey guys I have a problem similar to this... sorta. maybe I can get help as well. All my blinkers work, but the left front marker light only works (the one that stays on when bike is on w/o any signaling). The left side blinks at normal rate, and the right blinks at a fast rate. This started to happen I connected my LED integrated signal mirrors up for a minute (i plugged them in and then unplugged them after seeing that they worked) then noticed my right side blinks faster as if there is no blub. So my main problem I guess is that the left front marker light stays on while the left right marker doesnt, and one side blinks faster than the other. suggestions?
Posted: Mon Apr 05, 2010 6:34 am
BT,
As I wrote for some one else the blinker relay relise entirely on be loaded with the right power draw and that means that ALL the bulbs must be of equal wattage . take a look at yours also.
Posted: Wed Apr 07, 2010 2:35 pm
by Brutal Tooth
Just FYI, ask your state inspection guys if you need the marker lights to be working on your bike. Mine, here in TX, say they don't need to be on, they just need to blink.
