Carb sync fittings
megaloxana
Carb sync fittings
Post by megaloxana »
So i made a carb sync tool out of two bottles and 1/4 tubing BUT now i need fittings for the intake boots. Any ideas?
megaloxana
Re: Carb sync fittings
Don't you guys sync your carbs? :no
Post by thatkid »
I bought a very carb tool for that purpose. I split it with zero so it was only 55. Now I get super carb tuning ability. I believe you can get 6mm grease fittings from lowes/home depot/ace wherever and drill out the center. Then you use those. I think it's 6mm at least.
gooserex
Post by gooserex »
You can buy 6mm fittings from Motion Pro.
1989 Yamaha FZR600
40,500+km
- V&H Powerpak, K&N Pods, Stage 3 Jets, V&H 4-1 Super Sport, BT014's, PIAA Plasma Ion H4s
- 94' Fork Lowers, 96' Rear Rim, 02' R6 Brakes, Galfer SS Lines, .95 Racetech springs, Penske 8993 rear shock
- Ceramic Headers, Thermal Coated Radiator, PLX AFR, CRG RAC Levers
2004 Volvo V70 T5M
171,000+km
- IPD Poly mounts, QBR torque mounts, IPD HD TCV, Tiva CBV, PIAA Plasma Fogs, 35/20 Tint, K&N RX-4730, EST Heat shield, MSport drilled/slotted zinc rotors, FSD + Eibachs, Simons SportSystems Catback
1999 Ford SVT Contour Black/Tan
#2658 of 2760
252,000+km
- K&N, BAT Euro Kit (-1.5"), KVR CF pads, PIAA Plasma Ion HBs/H3s, Battery reloc, BAT y-pipe, Gutted headers, lightened interior and soon to be caged
Post by thatkid »
gooserex wrote:You can buy 6mm fittings from Motion Pro.
That too, but I was saying the cheap way. :lol:
Travis
Post by Travis »
mig welding tips 6mm, IIRC.
tommyj27
Level 9.5
Level 9.5
Post by tommyj27 »
we (buddy did the work, i watched) MacGyvered up a set by drilling out a couple 6mm bolts and tigging about an inch of (Aluminum?) tubing to the bolt heads. Worked like a champ.
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
Travis wrote:mig welding tips 6mm, IIRC.
I've heard this too....
megaloxana
interesting..never would have thought of that. thanks
megaloxana
Travis, I went out and bought some of those mig welding times and they worked great! Thanks a ton man. Only cost 7 bucks and I got 10 of them :thumbsup:
