THROTtLE CABLES
THROTtLE CABLES
I has to change my starter button becuase everytime i push it in it never wants to come back out so i would have to push it in and pull it out from bottom with my nail ,lol . So as i dissassembled the control box my throttle cables came undone .. so i tried to put them back one of them is the gas i suppose .. but whats the other cable on the backside? it started coming out its self and i just pushed it back in . When i give it gas my throttle goes back to its postition very slowly. Now im wondering if this cable on the backside has anything todo with it . Sorry if this doesnt make sense .
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
Re: THROTtLE CABLES
the other cable pulls the throttle back as its attached to the other side of the throttle setup so the throttle wont stay open.PIMPMYFZR wrote:I has to change my starter button becuase everytime i push it in it never wants to come back out so i would have to push it in and pull it out from bottom with my nail ,lol . So as i dissassembled the control box my throttle cables came undone .. so i tried to put them back one of them is the gas i suppose .. but whats the other cable on the backside? it started coming out its self and i just pushed it back in . When i give it gas my throttle goes back to its postition very slowly. Now im wondering if this cable on the backside has anything todo with it . Sorry if this doesnt make sense .
SOLD
SOLD
Re: THROTtLE CABLES
Yep second cable is as important as the first. Check to make sure that your throttle handle isn't binding along side the run/off switch housing and thereby contributing to your slow return to the closed position. That thing should "snap" closed and you should want it to "snap" closed. If it doesn't there's a problem somewhere.
Re: THROTtLE CABLES
You could not worry about it and use it as a cruise control...
Re: THROTtLE CABLES
M in KC wrote:Yep second cable is as important as the first. Check to make sure that your throttle handle isn't binding along side the run/off switch housing and thereby contributing to your slow return to the closed position. That thing should "snap" closed and you should want it to "snap"
There is no snap back motion when I had it disassembled.It had no pull on it infact, I think I could of pulled it out. I think I will have to check once I get home tonight from work.
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
Re: THROTtLE CABLES
Well this sucks , I get home after working 13 damn hours on my feet . Been waitin all day to come home and rise ,I suit up get ready togo and as i start my throttle makes a clickin noise .. i take off gas cover ,, pop off airbox . damn i see a cable dangling around by the carbs , i have no clue .. so i take the starter switch box apart and the dam wire pulls right out
this is what i need
this is what i got
well after scratching head thinkin where to get one tonight and getting back to reality
i put it back handlebar control back together without this cable , took it for a spin didnt seem to dangerous as long as i have control of the throttle .
Whats the worse case scenerio that could happen if i choose to ride it like this till my replacement comes in
BTW anyone have one of these laying around before i get one on ebay . thanks
this is what i need
this is what i got
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
Re: THROTtLE CABLES
Since it won't snap back into place you run the risk of full out gas in a panic. Or at stoplights if you don't put it back to idle it'll get really annoying for other around you. I doubt it will be an issue till the new one comes in. Just makes for one more thing you need to remember though which takes some attention off what's going on around you. Just be smart about it.
Re: THROTtLE CABLES
Dude I been riding all summer like that so far. Just remember.....keep her on two wheels till you get two cables. Mine goes back by itself it just lacks the snap but I dont have to manually throttle down or anything
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
- megaloxana
Re: THROTtLE CABLES
PIMPMYFZR wrote:Whats the worse case scenerio that could happen if i choose to ride it like this till my replacement comes in
Re: THROTtLE CABLES
If you got the money to fix it then I'd fix it. If you are broke like me then you ride it and save up for a new cable.
Good luck
Good luck
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
Re: THROTtLE CABLES
yea ive been riding like this for a while now, i just happen to come across it when i was changing my starter button . mine goes back its self also like urs just lacks the snap. but ive been poppin wheelies with it . Now i see im not only one who rides like this , i dont feel as uncomfortable. LOL2R3TARD wrote:Dude I been riding all summer like that so far. Just remember.....keep her on two wheels till you get two cables. Mine goes back by itself it just lacks the snap but I dont have to manually throttle down or anything
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
Re: THROTtLE CABLES
Very Seriousmegaloxana wrote:PIMPMYFZR wrote:Whats the worse case scenerio that could happen if i choose to ride it like this till my replacement comes inseriously?
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
Re: THROTtLE CABLES
Does anyone know if i can pick up a throttle cable at the stealership becuase i can only find one listing on ebay and it doesnt end for another 3 days ? And if they do have it do i have to buy both or just sell me the one i need ?
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
Re: THROTtLE CABLES
This will be another withdrawl from your $10.00 account while you are riding. This probably sounds like some secret code to some of you. But if you have every laied a finger on "A Twist of the Wrist" by Keith Code it will make perfect sense.
Bottom line is there is an infamtizmal amountof data that you process while riding a bike. All of this data processing comes at some expense to everyone's mental capacity. When you have to overly tax the thinking that is requied when riding you are more apt to missing something that under normal circumstances you would have detected. Ride safe my friend.
Some dealerships can make cables on the spot. Or you might get lucky enough to fine an OE cable laying on the dealerships shelf.
Re: THROTtLE CABLES
so i stopped at a dealer and asked for my cables .. from the picture i dispalyed can anyone tell me if its the pull cable or push cable .. thanks to first person who can tell me then thanks to rest of yall just for the hell of it ..
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
