FZR 600 post-storage idle/stall issue
Posted: Thu Jun 12, 2008 9:34 am
Sup Guys!
I am here from the archives forum and need some help!!
Here is my issue thread on FA:
http://www.fzrarchives.com/ipb/index.ph ... ntry386675
Please read the thread, but basicly i have an intermintant start/idle issue, maybe fuel related.
Here is my last post with the lastest update:
Good/then Bad update:
So a few weekends ago i did a carb sync on all of them with a diy made unit. After spending some time doing tehm in order; 1-2, 3-4, and then 2-3, things were good exept the idel was low/close to stall area (800 rpm). During my time here, I could not find the "idle adjustment screw" on my bike (CA Spec). Where the manual showed it, nothing was there...at all. In order to compensate for the low idel, i adjusted the last 2-3 carb settings a little off (3 pressure was higher) which improved the idle and running. The bike ran/idle'd (1200) and reved great!
During the last two weekends i started the bike twice, warmed it up and rev'd it for a little to make sure it was all set. Everything was fine....so i thought!!!
So on Sunday I started it fine, and ran it for 15 mins till the temp gague was almost as it is all warmed up. All was well so i shut it off. Then i started it again 20 minutes later to show a potential buyer and the idel was low and it stalled. I tried to start again it would crank, but not turn over. Sometimes it would turn over for a second then die and not start again. I thought it was cold again, so i started to use the full choke to start it, it did, then had a rough rpm run, then stalled and wouldnt start.
Then eventually, it would not start at all, full choke, half chock or none. Tempeture gague was at warm and the engine was warm. Very embrassing, needless to say.
These were very simular symptoms i had before my overhall/sync and i am dissapointed. The fuel pump does its thing for 5 seconds at pre-crank to turn on, everthing else at the seat area does as well. The fuel pump does not make any weird noise when i run it for a little, prior to stalling.
Few key points:
I installed a new VR (06 R6) that i had here and still nothing.
It has the orignal CR8E plugs since winter that i cleaned.
It has a new mixture of 93 & 89 octane gas in it (93 first at trank drain, then more 89 to idel/rev a few times.
Would the gas mixture be clogging up the carbs? Or the maybe the plugs are fouled?
If not, my only other guess is the fuel filter. I will replace the filter and plugs and see where i stand.
Then i may need to re-sync the carbs correctly with adjusting the idel screw (where ever it is!).
Any help on the idle screw location and potential issues? Your thoughts guys? Much appreicated!
Any help would be appreicated! Thanks.
Few key points:
